Reply
Trouble with wireless connection on Nighthawk AC1900
RyanHavey
Follower
Today I had my wireless connection interrupted today. I can't find my wireless network on any of my devices, and when i login in to my router login it says my wireless is offline. I never set it to turn off the wireless or anything like that. I don't seem to have an option to turn my wireless network back on. My desktop that is plugged into my router works fine but my wireless connection seems to have dissapeared and I can't seem to turn it back on in my router login. Any suggestions or thoughts? Thank you.
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 2
Guru
Re: Trouble with wireless connection on Nighthawk AC1900
Push the wifi on/off button on the router for 2 seconds. Kids/cats/others happen to hit that button and shut off the wifi quite routinely without people knowing.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 181 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
