- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Two R 6350 routers on same network connection issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I have installed two R 6350 routers on my home network. One is my main router and DHCP server while the other is setup as an access point. There are some devives connected wirelessly or wired directly to my main router while others are connected similarly to the access point.I have enebled access control on my Main router and blocked any new devices from connecting to the network. I have an IPPBX connected to the main router while an Analog Phone Adapter is connected to the access point. All these devices are successfully connected and I am able to access them on my LAN. But the IPPBX and the analog Phone Adapter don't seem to be communicating properly. Strangely, the devices connected to the access point are not shown in the main router's connected devices list while they shown on the access point's list. Besides, the access point's lis also shows the devices connected to the main router.
Please help me with this.
Could this be a double NAT issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Two R 6350 routers on same network connection issues
> [...] the other is setup as an access point. [...]
As in "Use the Router as a WiFi Access Point Only" in the R6350 User
Manual, or some scheme of your own? Visit http://netgear.com/support ,
put in your model number, and look for Documentation. Get the User
Manual. Read.
Devices connected to both R6350 units get (LAN) IP addresses in the
same subnet?
Not if one R6350 really "is setup as an access point" (which would
disable its NAT).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes. My main router has IP address: 192.168.2.1 while the access point has been assigned a fixed IP : 192.158.2.51. All other devices on the network (whether connected to the router or the access point) have IP addresses in the same subnet. I can access them as well. But the devices connected to the access point don't show up on the connected devices list of the main router.
I have configured the access point as per the user guide.
