Orbi WiFi 7 RBE973
Reply
Two wifi routers on two separate ISPs - will they interfere?
GoatCheese
I currently have a Nighthawk wifi router connected to one of our two ISPs.  I would like to add wifi to the other ISP.  I would like to buy another Nighthwk like the one I already have.  Will the two wifi routers interfere with each other?  Can I select different channels to keep them from interfering?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 3
antinode
Guru
Re: Two wifi routers on two separate ISPs - will they interfere?
> [...] I would like to add wifi to the other ISP. [...]
   What are you using with it now?
> [...] Will the two wifi routers interfere with each other? [...]
   If their radios' frequencies overlap, yes.  Same as if you have
(close) neighbors.
> [...] Can I select different channels to keep them from interfering?
   Normally.  You might find some relevant information in a widely
neglected resource:
      https://en.wikipedia.org/wiki/RTFM
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Read.  Look for "Specify Basic
WiFi Settings" (or "channel").
   Possibly interesting (regarding channel overlap):
      https://en.wikipedia.org/wiki/List_of_WLAN_channels
Message 2 of 3
GoatCheese
OK, thanks.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 318 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
