- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
UPnP not working properly in Firmware V1.0.2.116
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have just updated the firmware to V1.0.2.116 on my R8500 router.
Once the update was done, I soon discovered that the UPnP does not function normally:
For example, my QNAP NAS cannot detect my router and change the port forwarding setting.
Although I double checked the settings of both router and NAS and had a cold-restart of them,
the port forwarding setting does not resume.
Is there anybody experiencing the same problem?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, the problem is finally solved by resetting to factory default settings and rebooting for few times.
Thank you.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: UPnP not working properly in Firmware V1.0.2.116
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you.
