Reply
UPnP on or off ?
mattlindquist85
UPnP on or off ?
it is not letting me select my upnp so that i can enable it....hpw to i get it so that i can select it
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 6
TheEther
Guru
Re: UPnP on or off ?
Is your R7000, perhaps, running in Access Point (AP) mode? If so, there's no option to turn on UPnP because it doesn't make sense to.
Message 2 of 6
mattlindquist85
it is in ap mode we just turned it into router mode and now we are getting double nat error on our xbox...we are bridging our router and mediacom modem
Message 3 of 6
antinode
Guru
> getting double nat error [...]
   Put it back into AP mode.  Then, if you're interested in UPnP,
configure it on your (unspecified) "our router".
Message 4 of 6
mattlindquist85
our nighthawk model r7000 is what i couldnt enable upnp until i took it out if ap and out it in router mode....which then gave us a double nat....i read up that to fix that we need to enable the bridge mode on the mediacom modem....i have no clue how to do that
Message 5 of 6
TheEther
Guru
Does your modem have a UPnP setting? If yes, then enable it. Then you can leave your R7000 in AP mode.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 6779 views
  • 0 kudos
  • 3 in conversation
Announcements
