Reply
USB Control Center Freezing on Installation and/or Removal
ScoWeazy
IMG_20180817_215000.jpgI'm trying to download the USB Control Center, I'm running Windows 10 Pro N.  Everytime I install, it freezes at the same point.  When I try to repair or install, it also freezes.  I installed it on another computer and works great.
I have having to do a hard reboot when this happens.
I have the most current firmware installed.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 7
Accepted Solutions
ScoWeazy
Re: USB Control Center Freezing on Installation and/or Removal (SOLVED)
So apparently I had a bad installation that was causing problems.  I downloaded IObit Uninstaller which completely scraped off the bad install and then tried a fresh install.  Works great now.
Message 7 of 7
All Replies
What's that? The ReadySHARE Printer utility?
There is support material, including a manual and any additional software, for the R7000 somewhere at the end of this link:
>>>> R7000 | Product | Support | NETGEAR <<<<
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 7
IrvSp
Master
This doesn't sound like a Router problem? However, if it is a program (unknown what USB Control Center means?) then your PC is the problem. Check the Event Viewer for some hints...
Message 3 of 7
ScoWeazy
Yes, the readyshare printer utility.
Message 4 of 7
That threw me too.
Go look at the Readyshare controls in the browser interface, then ReadyShare Printer:
Step 3: On each computer that will share the printer, download the NETGEAR USB Control Center utility from http://www.netgear.com/readyshare.
Unfortunately, even when you visit the link you are left not much wiser. Heaven only knows which of the various bits there counts as the "Control Center".
Just another user.
Message 5 of 7
If the utility is the one on this page, it seems to be out of date and limited to the number or routers supported.
ReadySHARE: Your Router Can Do Everything | NETGEAR
The R7000 is in there.
Is that the software you ran? It installed here in Windows 10 Pro 64 bit.
Just another user.
Message 6 of 7
ScoWeazy
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 1353 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
