Reply
USB Drive Storage Read Write Access R9000 set up as Access Point
bsinger
I use a R9000 as an access point and have a desktop hard drive attached to the R9000 USB port. I have mapped this to a drive in Windows 10 and have no problems accessing or editing files when connected directly to the R9000 via wifi.
The problem comes when I connect via a wired connection to the main router (not the R9000). In this case I can see the R9000 through Windows 10 File explorer but I do not have write access and it is not mapped. This same situation is occuring when connect to the main router via wireless.
I can't switch the routers as a work around. The main router is 192.168.0.1 and the R9000 is 192.168.0.2.
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 6
DarrenM
Sr. NETGEAR Moderator
Re: USB Drive Storage Read Write Access R9000 set up as Access Point
Have you done the following steps in this kb?
DarrenM
Message 2 of 6
bsinger
is there a link you are referring to?
Message 3 of 6
DarrenM
Message 4 of 6
bsinger
From my original message "I have mapped this to a drive in Windows 10 and have no problems..."
The problem is not mapping. I don't need a kb about mapping.
thanks
Message 5 of 6
bsinger
Now it works. I changed nothing that I am aware of
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 957 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
