Orbi WiFi 7 RBE973
Reply
USB Sticks connected to R8000 cannot copy large files - invalid file handle error
vinnynasoz
I was trying to copy large .ISO files to the USB sticks connected to my R8000 WiFi router's USB ports. I have tried both USB ports and both give me the same error whenever I try to copy and paste a large file into them.
The error I get is "invalid file handle".
Does anyone know why this happens?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 5
Accepted Solutions
JamesGL
Master
Re: USB Sticks connected to R8000 cannot copy large files - invalid file handle error
Hi vinnynasoz,
What is the format of your drive? Have you tried other USB drive and check other type of format like NTFS or FAT32. The reason as the drive may not support .ISO files.
Message 2 of 5
All Replies
JamesGL
Master
Hi vinnynasoz,
Message 2 of 5
vinnynasoz
You are right. The problem was my USB sticks were in FAT32 format. I formatted them to NTFS and it works perfectly.
Message 3 of 5
JamesGL
Master
Hi vinnynasoz,
Great to know it works fine now.
Message 4 of 5
VE6CGX
Master
The error message alredy gave you a pointer there, LOL!
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2438 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
