Reply
USB functionality
CrossingMidnite
USB functionality
My new wifi router has a usb-3 port.  I tried making an ethernet connection to my PC by conecting with a usb-3 cable and failed.  Is this theoretically possible even?  There is no ethernet port on my Lenovo (WIN10) so it would be convenient if it is possible
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 9
Guru
Re: USB functionality
You can't use an adapter on the usb port on the router to add a port.
You can use a usb 3.0 adapter on the laptop side and go ethernet to the r6700.  You would need to check which adapters are compatible with your laptop specifically.
Current Setup: CM2000-> SXK30-> GS716v2-> RAXE500->
Message 2 of 9
CrossingMidnite
USB3 to USB3. I was thinking that if my Lenovo can connect to the internet via a usb cable which has an ethernet plug on the other end, then it can receive/send the same when there is a usb plug on the other end.
Message 3 of 9
Guru
Unfortunately no, that won't work. You'd be better to spend the $ on a network switch if you need more ethernet ports for the router.
Message 4 of 9
myersw
Master
Other option is to buy a USB to Ethernet dongle. They are not that expensive. Anker makes nice ones. Have used on my MAC Pro laptop.
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 5 of 9
CrossingMidnite
Excuse me? None of my ports are in use !!! !!! None. All empty sockets.
This topic us now all yours. I am starting a new one. Please stay out of it !
I did not run out of ethernet ports. I did not use an adaptor. I am not trying to increase the number of usb ports.
Message 6 of 9
schumaku
Guru
@CrossingMidnite wrote:
USB3 to USB3.
Even if some USB standards allow using the same plug, it's still a USB host and a USB device. Two USB hosts can't be connected directly, and so can't two USB devices.
What's the point of (not) considering the suggested USB 3 to Gigabit Ethernet adapter on the Windows 10 system side?
Message 7 of 9
antinode
Guru
> My new wifi router [...]
   Is that your "My new wifi router"?
> [...] has a usb-3 port. I tried making an ethernet connection to my
   Ethernet and USB are two different things; incompatible physically,
electrically, logically.  Are you trying to say that you used some kind
of USB cable to connect your "My new wifi router" with your
(unspecified) "my PC"?  Or some kind of USB-Ethernet adaptor?  Or what?
> [...] Is this theoretically possible even? [...]
   Is _what_ theoretically possible?  Can USB used for a network
connection?  Sure.  Get a Rasberry Pi Zero, and that's about all you
_can_ do.  All you need is appropriate software on both ends.  And I
rather doubt that you'll find any such software on any Netgear router.
> [...] There is no ethernet port on my Lenovo (WIN10) so it would be
   Get a USB-Ethernet adaptor?  Use a wireless connection?  Many things
are possible.
> [...] I was thinking that if my Lenovo can connect to the internet via
   There's more than "cable" in a USB-Ethernet adaptor.
> of it !
   You might consider the advantages of at least pretending to be grown
up.  Your original problem description was an ambiguous mess.  Expecting
anyone to extract your intended meaning from it was unrealistic.
Getting all huffy about unsuccessful attempts to determine what you
actually want to do is silly.
   If you do start another thread without providing a better problem
description, then you can reasonably expect similarly unsatisfactory
results.
Message 8 of 9
IrvSp
Master
Before you go of in a huff, let me take a whack at this?
Your router (no model number, but that doesn't pertain I think to the question) has a USB 3.0 port. Many do (and some have a USB 2.0 port as well).
You have a USB cable and you connected your PC to the route that way? Correct? You think it should then pass the Internet signal onto the PC, correct?
Sorry, it doesn't work that way. See :
https://kb.netgear.com/24693/How-to-access-your-USB-device-on-the-N450-CG3000Dv2
https://www.netgear.com/home/discover/apps/readyshare.aspx
http://www.zelect.in/router/what-is-the-use-of-usb-in-router
If you read this, you should understand what the USB port is used for.
So the answers you got are correct, either buy an Ethernet to USB or Wireless to USB device if you want the laptop to use the Internet.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 902 views
  • 0 kudos
  • 6 in conversation
Announcements
