Orbi WiFi 7 RBE973
Reply
Unable to Register ReadyCLOUD on Nighthawk AC1750 (R6700)
Zafar2010
Hello,
I am unable to Register my ReadyCLOUD account on my router via the routerlogin.net page. After entering my Netgear account login credentials i am getting the message "This router is regisered with the following ReadyCLOUD user (my account)" for a split second. This message disappears and then "Registration failed" message appears.
I am able to login to the ReadyCloud site with the credentials however.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 12
Accepted Solutions
Zafar2010
Re: Unable to Register ReadyCLOUD on Nighthawk AC1750 (R6700)
This issue was resolved. I had to setup it up in router mode for the ReadyCLOUD to work. Thanks to Netgear support.
Message 12 of 12
All Replies
JamesGL
Master
Hi Zafar2010,
What is the firmware version of the router?
You can try to use a different browser or different computer to register.
Message 2 of 12
Zafar2010
Hi the firmware version is V1.1.0.42_1.0.1
I also tried using another browser and got the same result unfortunately.
I even got the same error on my phone browser.
Message 3 of 12
JamesGL
Master
Hi Zafar2010,
Can you check the timezone of your router? Make sure it is correct. That's under advanced tab> security> schedule.
Message 4 of 12
Zafar2010
Corrected the time zone but I'm still getting the issue. Does it have to be setup in a modem mode because i set mines up as a router.
Message 5 of 12
JamesGL
Master
Hi Zafar2010,
What is the exact model number of your device?
Message 6 of 12
Zafar2010
AC1750 (R6700-100NAS)
Message 7 of 12
Zafar2010
I'm seeing R6700v2 on my product warranty info..
Message 8 of 12
JamesGL
Master
Hi Zafar2010,
Did you configure it under basic tab or advanced tab?
Message 9 of 12
JamesGL
Master
Hi Zafar2010,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 10 of 12
Zafar2010
I tried under both the basic and advanced. Same result both times.
Message 11 of 12
Zafar2010
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 1778 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
