Reply
Unable to Rename Attached Devices
rkruz
Luminary
I cannot rename attached devices.
Viewing the "Attached Devices" page.
CHeck box a Device, the "Edit".
I will make a simple change as in the "Device Name", then "Apply"
When the page refreshes there is no change.
THen I force a "Refresh" and the Device Name will still not change.
This is the same for any device and any field in the attached devices.
What can I do to get this to work?
Thanks
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 11
rkruz
Luminary
Re: Unable to Rename Attached Devices
The firmware is latest at 1.0.4.78_10.0.55 and I cannot update the Device Names.  Thanks
Message 2 of 11
mrollinsiv
Luminary
I'm also having issues updating names firmware V1.0.4.28_10.1.54 (Latest)
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 3 of 11
rkruz
Luminary
Not a solution but a clue.   I removed all the ethernet connections on the back of the router and then I was able to Rename a wireless attached device.  When I reattached the 4 ethernets I was no longer able to rename the wireless attached device nor another other.  The one thing I have not tried is to restore the router to factory settings but I dont want to do that because I thnk it will cause more problems for me.  In all my research there is no way to report the issue to Netgear if the router is past 90 days.
Message 4 of 11
DarrenM
Sr. NETGEAR Moderator
Do you have a Roku device attached to the network?
DarrenM
Message 5 of 11
mrollinsiv
Luminary
So I was eventually able to update the names by "gaming" the system. I had to go into each connected device and actually set an icon and then change the name. It appears there when trying to save without one selected fails. This appears to be a bug in the code.
I'll take this time to also point out the options for icons are horrible. Very limited.
Message 6 of 11
rkruz
Luminary
no roku in the system
Message 7 of 11
rkruz
Luminary
that would be easy.....but no it doesnt work for me.   I tried is many times in several different orders and the changes never were made upon page refresh.
Message 8 of 11
schumaku
Guru
There are kind of systematical issues with your router firmware, some API, and probably the mobile App API if involved. The community is full with similar reports - almost every Netgear router does behave a little bit different, also depending on the number of attached devices. One more for the Netgear router buglist @Christian_R
PS. the duplicated entries on the same subject by the same users should be merged - this is a pain and a wast of time.
Message 9 of 11
Paul-Jan
Luminary
Same problem! AC1900 R7000 Firmware version V1.0.9.88_10.2.88
Not possible to change names or edit.
Also the email settings / messaging will not stay and it will not work either.
It also does not work after a full reset!
Model: R7000|AC1900 Smart WIFI Router
Message 10 of 11
robcampbell
Luminary
I am able to change the name but when I restart the router, the names aren't saved.
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 1923 views
  • 2 kudos
  • 6 in conversation
Announcements
Orbi WiFi 6E
