Reply
Unable to change Read/Write access for shared USB storage
m00nshake
Luminary
Hello everyone:
I'm trying to modify the read/write access column for my shared USB storage so that remote connections to my USB drive will require a password. Right now, it is set to All - No Password for both Read/Write. When I click the edit button, it just refreshes the same screen. I've also had the same problem with setting up a new DDNS server, where it just refreshes the page when you click Register. I am guessing that this is a firmware issue. I'm just checking to see if any of you are able to replicate this issue, on the latest firmware V1.0.2.194_1.0.15 or any older firmware. If you are running older firmware but not having this issue, it would help save me some time of downgrading just to find out it doesn't work. Thanks.
Message 1 of 5
asb58
Luminary
Re: Unable to change Read/Write access for shared USB storage
I had the same problem when clicking 'Create Network Folder'. Make sure your browser isn't blocking popups!
Message 2 of 5
Fairytail
Virtuoso
Make sure that pop-up blocker is disabled on your browser.
Message 3 of 5
m00nshake
Luminary
This fixed the problem. And the problem with registering mynetgear.com DDNS. Thanks so much.
Message 4 of 5
Fairytail
Virtuoso
That's great to know that it's working now.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 7012 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
