- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Unable to connect any device at 5GHz to AC1750/R6700 Router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unable to connect any device at 5GHz to AC1750/R6700 Router with V1.0.0.26_10.0.26 firmware. I've tried different channels but still no luck. I've tried to connect using my iPhone 6, Dell laptop, Apple Mac Air, Samsung TV, etc. Nothing works. Does anyone have a suggestion on how to resolve this issue?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi br2628,
1. Reset the router to factory default.
2. If still the same, try this firmware
http://kb.netgear.com/app/answers/detail/a_id/29849?cid=wmt_netgear_organic
JamesGL
Community Team
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi br2628,
JamesGL
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Unable to connect any device at 5GHz to AC1750/R6700 Router
Hi br2628,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
I backleveled the firmware to v1.0.0.24_10.0.18 and now all devices can connect to 5g on the router. Thanks for your help!
Strange that newer firmware doesn't work. NETGEAR should be updating the lastest version of firmware to allow devices to connect at 5g.
Thanks again,
Bob
- Mark as New
- Bookmark
- Subscribe
- Permalink
Some 5g channels aren't available in some regions. Do you remember the channel, is it the same?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm using channel 153. I believe the problem started when I updated the firmware a while ago. When I was troubleshooting this issue, changing the channel had no affect.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Understood, BUT did you try a lower 5g channel 36~48
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes I tried all channels.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi br2628,
If you are still using the previous firmware, which is working, try to load the latest firmware and reset the router.
JamesGL
Community Team
