Reply
Highlighted
Unable to login to websites
I swear this unit is an Orbi Router RBR40.
Had to reconnect with cable modem and reset and now I cannot log into websites. I am prompted to “login” with a “user name and password” This is not right. Bought this unit maybe 2 years ago?
I saw someone inquired on this issue in 1/20 but did not see a resolution. Any help? Thank you.
Model: CBR40|Orbi AC2200 Tri-band WiFi Cable Modem Router
Message 1 of 4
Highlighted
Re: Unable to login to websites
That’s frustrating...
Message 2 of 4
Highlighted
You mentioned you reset it? As in factory reset it? Your username and password will be set back to default in that case.
Should be
username: admin
password: password
Message 3 of 4
Highlighted
Prodigy
When you do a reset you have to hold the reset button in for say 7-10 seconds or until lights start flashing. Just poking the reset button does nothing other then make you feel good. Smiley Wink
Modem CM2050V
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 75 views
  • 0 kudos
  • 3 in conversation
Announcements
