StigKannegaard's avatar
May 29, 2018
Unable to map network drive on R7000 after enabling VPN
Hi, I have a network drive that has worked fine for long time - after having enabled VPN on my R7000 I'm no longer able to access it or map it again. Using the WD software I can see it's working as should, but.....
Thanks
Stig
  • IrvSp's avatar
    IrvSp
    May 30, 2018
    It is quite possible the drive is corrupt. Can you try connecting the drive to a PC directly, that is into a USB port on a PC?
    I say that as I had a similar problem and when I did that the PC had to run CHKDSK before it could be used on the PC.
    Can you use NET USE to connect to it and assign a drive letter and view it? Like this:
    C:\>net view
    Server Name            Remark
    \\IRV8700              Irv's 8700
    \\READYSHARE           readyshare
    The command completed successfully.
    C:\>net view \\readyshare
    Shared resources at \\readyshare
    readyshare
    Share name       Type  Used as  Comment
    USB_2.0_Storage  Disk           read:admin;write:admin
    C:\>net use x: \\readyshare\usb_2.0_storage
    C:\x:
    X:\>dir
     Volume in drive X is USB_2.0_Storage
     Volume Serial Number is 6F06-9E72
     Directory of X:\
    03/16/2018  02:25 PM    <DIR>          $RECYCLE.BIN
    05/26/2018  07:28 PM    <DIR>          .
    01/01/2015  01:00 AM    <DIR>          ..
    05/12/2018  01:39 PM    <DIR>          netgear_downloader
    05/12/2018  11:05 AM    <DIR>          Pictures
    03/05/2012  06:44 PM         1,644,118 SeagateExpansion.ico
    01/13/2016  10:00 PM           611,096 seatools-for-windows-en-us.pdf
    05/12/2018  11:25 AM    <DIR>          share
    05/12/2018  01:37 PM    <DIR>          System Volume Information
                   3 File(s)      2,255,233 bytes
                   9 Dir(s)  1,208,330,563,584 bytes free
    Not sure if that will work though if the disk is corrupt or not?
  • The resource browser since Windows 10 Creator does not locate SMB 1 resources unless the SMB 1.0 is re-activated after an upgrade. I have had issues when the USB is activated on an R7000 and it seems to become the Master Browse on the network.
    If the resource has not changed, you can potentially still find it using RUN (right click on on Start Menu choose Run) and enter the resource name, i.e. \\NetworkDriveName
  • StigKannegaard,
    What OS are you using?
    If you remove VPN does it work as it did before?
    What firmware is installed?
    Any other changes have you made?
    What are all the troubleshooting steps you used and made?
    If on Windows, open a CMD prompt and enter NET VIEW. Do you see the USB share?
    If on Windows, open Windows Explorer and expand on the left side NETWORK, do you see the USB Share?
    What if ANY error codes or dialog error windows did you get related to this?
    • Hi IrvSp,
      Windows 7 Professional, SP1
      I have not tried to remove VPN, but have tried to run without VPN activated - problem unchanged.
      Firmware V1.0.9.26_10.2.31  on my R7000.
      No other changes.
      My network drive is a Western Digital MyBookLive - when I use the WD software, I see the drive OK, working, but when I try to MAP NETWORK DRIVE I get the message (error) as attached.
      When I click the Windows Network Diagnostics, I the second error attached.
      Running the CMD prompt, I get the 3rd error.
      See attachment 4 for what I see in Windows Explorer - where I DO see it.
      Thanks
      Stig
      • IrvSp's avatar
        IrvSp
        Master
        C:\>net view
        Server Name            Remark
        readyshare
        C:\x:
        X:\>dir
         Directory of X:\
