Reply
Unlock Region AC1600
KazzaCollins
Follower
I recently moved to Japan and brought my WiFi router with me. Because I can’t change the region from United States in the settings it does not work. I have tried the tips mentioned in other comments but have been unsuccessful. Is there any other way to fix this or should I get rid of my NetGear product.
Model: C6250|AC1600 WiFi Cable Modem Router
Message 1 of 2
antinode
Guru
Re: Unlock Region AC1600
> [...] AC1600
   "AC1600" is a speed, not a model number.  Look for "Model" on the
product label.
   Is that accurate?  Fiddling with the firmware on a Cxxxx model might
be more difficult than it would be on a non-DOCSIS device.
> [...] I have tried the tips mentioned in other comments [...]
   Think, for a moment, about how little useful information that
(non-)description conveys to the non-psychics in your audience.
> [...] but have been unsuccessful. [...]
   Not knowing what you did, or what happened when you did it, makes it
tough to guess what might have gone wrong.
   Did any of those "other comments" mention "burnsku"?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 148 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
