Reply
Unusable Internet when saturating usb drive (6700v3)
Dougie18
Tutor
So I've ran into an issue where if I'm connected to the router via ethernet and start a transfer to my hard drive plugged into the router ,my internet speeds on all my devices (both ethernet and wifi) slows to a crawl. I'm not sure if this is a bug or just a side effect of maxing out system resources on the router. I go from about 360 mb down to .3 when doing a scheduled backup.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 2
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: Unusable Internet when saturating usb drive (6700v3)
Yes, you could be maxing out the router you may want to try using QOS so those other devices still have priority.
DarrenM
Message 2 of 2
All Replies
DarrenM
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 386 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
