- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Updated Firmware on R7800 now ReadyShare drive not shared with Plex
Everytime I touch this router it ruins my day.
I unfortunately decided to update the firmware because I haven't done it in forever. Now my media is not sharing with my shield device properly.
1) how can I tell what firmware I had installed on the router before the update?
I suppose if I can figure that out, I can figure out how to re-install that firmware.
on a side note, the parental controls STILL do not work & they never did. (that REALLY still makes me angry)
Thanks if you can lend a hand since Netgear support always refused to help me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Updated Firmware on R7800 now ReadyShare drive not shared with Plex
Out of Warranty Support I guess?
As for backleveling the firmware, really easy.
- Go to the Support Page
- Enter your model number
- Select Downloads
- You'll see a list and at the bottom prior version button
- Locate one you are interested in and D/L it.
- It will be a ZIP file, unzip it to a location you remember, should contain a README and a .CHK file
- Open Genie on a brower and log in.
- Go to ADVANCED, ADMINISTRATION, ROUTER UPDATE.
- Use BROWSE button to locate the .CHK file and OPEN it
- Ignore the message that says the F/W is older and proceed.
- Done
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
thx...will read your post...I was out of warranty from day 1...Bought new open box from amazon. That screwed me out of support. Also spent 100 hours trying to get parental controls set up years ago to no avail....Now firmware screwed me over by messing up my readshare drive. What does this all mean?...
I WILL NEVER TOUCH another Netgear product since they can seem to deliver what they sell.
...but thank you for your help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I feel for you... I bought my R8000 from Amazon as well but I opted for the SUPPORT plan... 4 years for $5.38... it is questionable if it covered firmware problems, but for that price, I got it, if nothing else 4 year protection from a h/w failure.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
still not able to see the readyshare drive in plex anymore...this is SOOOOO irritating.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
There are MANY people that have this issue...how on earth can this not be fixed by now?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
For parental controls did you follow these instructions and enable OpenDNS?
https://kb.netgear.com/25687/How-do-I-configure-Live-Parental-Controls-on-my-NETGEAR-router
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
funnily. the same advice as
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/connectivity-issues-since-new-firmware-1-0-4...
use voxels fw for x4s. it is the same as a ng stock but all ng bugs are fixed. the link is
https://www.snbforums.com/threads/custom-firmware-build-for-r7800-v-1-0-2-53sf-1-0-2-53sf-kf-updated...
no issues. rock solid. flush above your stock. setting are kept.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks ...I was just about to try that. Should I go ahead and do the 30-30-30 reset?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
and in regards to Parental Controls, I continually had (and it didn't work today either) issues with OpenDNS interacting with the Netgear stuff...not logging in etc. I had hoped it would work with the new firmware as opposed to what I had a couple of years ago
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
thank you...will try it!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
No luck with mod firmware. (Did factory reset 1st)...then did 30 30 30 reset and installed latest normal firmware...no luck. played around with Windows Credentials...no luck....turned SMB1 windows options all on and all off...both ways no luck. I cannot access these STUPID readyshare drives. This is ridiculous. No end user should EVER be put though this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@MontyTheLab2, I'm sure you are having problems, but can you give some details?
What are the troubleshooting steps you took, what were the results, and what did you see or get as an error? "no luck" doesn't help understand what had happened?
Windows Credentials usually will be used to allow access and not require UID and P/W before connecting... were you getting prompts for those?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
DD-WRT, RMerlin (the Asus Merlin firmware dev) and some OpenWRT devs have also spoken of this.
DD-WRT
https://wiki.dd-wrt.com/wiki/index.php/Hard_reset_or_30/30/30
SNB Forums - Rmerlin’s post is midway down and even at Thiggins the reviewer seems to se it as more of an urban myth:
https://www.snbforums.com/threads/30-30-30-resets-voodoo-or-real.26534/
He says on some models it can actually causes issues.
The 7800 troubleshooting simply says to use the pin reset for a few seconds till it blinks amber and that’s pretty much what I would use, if GUI method via admin settings was not available.
https://kb.netgear.com/30180/R7800-FAQs
I myself have not used this in over 4 years having tested various models for Netgear and going back and forth between OpenWRT/DD-WRT and stock on various routers. Last time I did a 30-30-30 was on a WNDR3700v2 and WNDR3800 in 2014.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@avtella, the 7800 reference says this, "for over five seconds until the Power LED blinks amber.".... and holding it longer probably wouldn't matter.
The other one with 'damage', speculative at best. " Using this today is a bad idea, as it flat out won't work with certain models, leaving you with a router in recovery mode instead of with a cleared nvram.
Always best to go with the procedure documented by the router manufacturer."
I do know at 'one time' doing the 30-30-30 worked, wiped out ALL settings on my R7000, but later f/w that didn't happen, settings remained. There was a change in the R7000 firmware though that you can do it in Genie via a browser, an ERASE NVRAM button. Never really documented and USELESS if one needs to reset the router due to a problem stopping them from logging into the router. Other changes in the readme as well, and even in setup of the router when NEW. Latest README's do NOT have 2 statements, must use wired connection, and do a reset after installing. My R8000 has a sticker on it telling me to use the NIGHTHAWK tablet/phone app to set it up.
I don't know why NG has not completely documented this or why only on some models.... but anything not on a NG KB or posted here by a Moderator (as a Sticky) I wouldn't reply on as fact.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
1. GUI factory reset if available after firmware upgrade if new issues arise possibly due to old configuration data etc.
2. Pin in reset button till power light blinks amber if option one is not available. Will have the same effect as above.
The one that defiantly has issues with 30-30-30 are some of the Linksys models according to BrainSlayer as apparently it can cause them not to recover at all, I’d assume he’d know as he tests these.
