Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Updated/restarted now power light blinks and won't work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-22
06:41 AM
2020-12-22
06:41 AM
I updated my router firmware for the first time and once it restarted it only came back on with a blinking power light. I tried restarting and even turning off the power but nothing has changed.
Model: R7900P|Nighthawk X6S AC3000 Tri Band WiFi Router
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-22
07:51 AM
2020-12-22
07:51 AM
Re: Updated/restarted now power light blinks and won't work.
blinking power lights tends to indicate a corrupt firmware issue.
What you can start with is a factory reset. While powered on, push and hold reset for 7-15 seconds. If that doesn't work, then move onto recovering via tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
Message 2 of 2
Announcements
