- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Upgraded firmware and had a performance degradation.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I updated to the newest firmware for this model over the weekend and noticed that I lost 50Mbps from my download speed. Since my max for the package that I have is 150Mbps, it was very significant drop.
Did all the troubleshooting steps, even had the internet provider out here looking at stuff. He traced it back to the router. So I rolled back the firmware to V1.0.5.28 and my performance return to normal.
Did anybody else have that experience? Is it perhaps a sign that my router is going to bite the dust?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Upgraded firmware and had a performance degradation.
Probably not. Equally likely that there is a problem with the firmware you used. It has happened.
Measured how? Not wifi, I hope. That is not reliable and depends on wifi clients.
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
You can reduce the hassle of reconfiguring all those settings by creating a backup of your settings before you reset. Then if something is still broken after the reset, and the new firmware has not fixed it, you can restore the device to its pre-reset state.
You could even try restoring the settings even if the new firmware has fixed the problems, but be prepared for the restore to also bring back your problems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So I have also done the factory reset. But the download times tested at the router still fluctuate a lot. 106 Mbps down to 148 Mbps down.
Are there any more troubleshooting steps? Or is this router starting to go south?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is there any pattern to this? That is a wide variation, but ISPs can have different traffic loads at different times of the day. Likewise the speed test sites.
At least you sometimes get the peak speeds you'd expect.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@boojiboy71 wrote:
It is a fiber optic connections, so I am well below the available broadband.
I'm not sure what that means.
After the speed drops, does it stay like that?
The fact you recovered some of the speed after rolling back to the previous firmware version suggests something nasty there. With luck they will mend it in a new release.
Did we ever get into your modem, if there is one? What is it? I should have asked earlier.
- Mark as New
- Bookmark
- Subscribe
- Permalink
