Orbi WiFi 7 RBE973
Reply
Upon setup router says it can not detect cables.
Aosbornefl
Tutor
I just recently moved and have a new internet service. I have factory reset the router, upon setting up the router again when it goes through the steps it says it can not detect cables, I click the question mark at the top right of the Netgear app and it says to make sure Ethernet cable is connected on both ends. I’m using a brand new Ethernet cable, I’ve tried an old one, I’ve reset the modem and the router and I still can’t get it to work.
Model: R7450|Nighthawk AC2600 Smart WiFi Router
Message 1 of 8
Guru
Re: Upon setup router says it can not detect cables.
What modem/gateway is it?
Message 2 of 8
Aosbornefl
Tutor
The modem is Model# TC8717T. I don’t know what you mean by gateway, the provider I use is spectrum internet.
Message 3 of 8
Guru
the  TC8717T is a modem/router combo device. its not strictly a modem.
Unless you have it in passthrough/modem only mode (not all device implement properly) it can put you in a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
options?
1. put the TC8717T in modem only/pass through mode
2. put the netgear's ip address in the TC8717t's dmz
3. put the netgear in access point mode.
just use one of those modes.
Message 4 of 8
Aosbornefl
Tutor
How do I put my Netgear in access point mode?
Message 5 of 8
Guru
Message 6 of 8
Aosbornefl
Tutor
Thank you. But how do I get to this point if it doesn’t fully let me setup the router? Everytime I’m in the process of setting it up it can’t detect the cables, I close the app and reopen and it makes me start the process over again. Do I just need to set my modem to pass through mode?
Message 7 of 8
That would be the best option. If you put the R7450 into AP mode you lose a lot:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
Try this:
  • Unplug PC from network
  • Plug R7450 into PC
  • Set up R7450 in AP mode
  • Unplug R7450 from
  • Plug in PC
  • Plug R7450 into the modem/router
  • Turn off and unplug modem.
  • Turn off router and computers.
  • Plug in and turn on modem/router. Wait 2 minutes for it to connect.
  • Turn on R7450 and wait 2 minutes for it connect.
  • Turn on computers and rest of network.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 583 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
