Orbi WiFi 7 RBE973
Reply
Use RBR50 as a satelite
Wim_Merlijn
Tutor
Hi,
I do have a RBK50 (with RBR50 and RBS50) and want to extend with a RBS50.
But can't purchase new RBS50.
So I a thinking of buying Wifi 6 router (RBK852) and use the RBR50 as a satelite of the RBR850)
Is that supported, will it work?
Thanks in advance for your reply.
Wim
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 6
Accepted Solutions
Guru
Re: Use RBR50 as a satelite
Not as a satellite. you can hardwire it in and set it up as its own access point
Message 4 of 6
All Replies
Guru
With the RBR50 system, there's several satellites you can use.
RBS20
RBW30
RBS40
RBS40V
RBS50
RBS50Y
Message 2 of 6
Wim_Merlijn
Tutor
Thanks for your quick reply.
But is it also possible to use the RBR50 as a satelite of a new Netgear Orbi router?
Message 3 of 6
Guru
Message 4 of 6
Wim_Merlijn
Tutor
Okay and thanks again.
Best way is to find/ buy one of the satelites:
RBS20
RBW30
RBS40
RBS40V
RBS50
RBS50Y
Message 5 of 6
Guru
Best way or cheapest?
I've seen several of the "kits' on amazon for renewed.
I've bought them before just for the satellites as it was cheaper to buy a kit and sell the router than it was to just buy a satellite.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1847 views
  • 4 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
