Reply
Use multiple external hard drives
Steppin
I have a 4TB 3.0 usb drive connected to the R7000 3.0 port.
I have a Printer connected to the 2.0 port.
This setup works fine...
But I need to add another drive and it's a 2.0 external drive. I tried a usb hub that I connected to my 2.0 printer and External drive.
Both drives keep disconnecting when I upload or download about 500mb or more from either one of them.
Is there another way I can set this up?
Message 1 of 11
R01k
Follower
Re: Use multiple external hard drives
Why not connect the printer to a PC? What about a WiFi printer?
Message 2 of 11
Steppin
I don't have a wifi printer and this way multiple laptops and tablets can print.
Message 3 of 11
R01k
Follower
Did you try hooking both HDDs to the hub?
Message 4 of 11
VE6CGX
Master
Hi,
Some USB hubs are known to work. Ultimately move to NAS box.
Message 5 of 11
Steppin
yes no luck.
Message 6 of 11
Temporel
Novice
Steppin, any of your computer can share the printer.
Message 7 of 11
R01k
Follower
But I bet he doesn't want to have a PC on all the time.
Message 8 of 11
Temporel
Novice
people have weird needs. There are wifi adapters for USB printer, he could also just get a bigger HD instead of 2. WiFi printer are cheap these days ($30.00 for an HP). He could by a NAS, he could also get a decent USB hub. Nope, he just want to use his current setup which doesnt work.
Message 9 of 11
Steppin
what is a decent usb hub?
Message 10 of 11
jsaelman
Hey Steppin,
I wouldn't go buy any other USB hubs if you're not even sure this is the problem. Neither would I throw away my current setup ;-)
What you can do is connect your printer to a spare ethernet port on your router (or switch). To do this, you need a printserver with both a USB 2.0 and an ethernet connection.
google on 'printserver usb ethernet' and you'll get plenty of results starting at around 20 euros.
I'm not sure if I'm allowed to advise brands, since I just recently joined the forums, but you should be able to find a cheap solution with this.
Good luck
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 4124 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi WiFi 6E
