Orbi WiFi 7 RBE973
Reply
Using AC2300 Nighthawk Model#R7000P as wired WiFi extender through Netgear switch (GS308)
BladeParker
From what I understand this should be possible. I want to use the R7000P as a wired WiFi extender with little configuration and as low maintenance as possible. Please clarify my terminology if needed and point the way to some documentation, it would be greatly appreciated.
ISP Router <wired-to> GS308 <wired-to> R7000P
  • I want WiFi coming from my ISP Router
  • I also want WiFi coming from the R7000P (If possible to have the same WiFi connection/name as the ISP, that would be great. Understandable if this requires a second WiFi connection/name)
  • I am not looking for wireless WiFi extender solutions, only wired
  • If the R7000P needs to be directly wired to the ISP Router, that is an option although not prefered
  • If the R7000P cannot do this, please recommend another Netgear solution
Router: https://www.netgear.com/home/products/networking/wifi-routers/R7000P.aspx
Switch: https://www.netgear.com/support/product/GS308.aspx
Thank you.
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 3
Accepted Solutions
antinode
Guru
Re: Using AC2300 Nighthawk Model#R7000P as wired WiFi extender through Netgear switch (GS308)
> [...] I want to use the R7000P as a wired WiFi extender [...]
   The phrase is "wireless access point".
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Look for "Use the Router as a
WiFi Access Point".
   The network switch should be harmless.
> o I also want WiFi coming from the R7000P (If possible to have the
> same WiFi connection/name as the ISP, that would be great. [...]
   I'd run the experiment.
Message 2 of 3
All Replies
antinode
Guru
WiFi Access Point".
Message 2 of 3
BladeParker
Thank you! Smiley Happy
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1291 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
