Orbi WiFi 7 RBE973
Reply
Using r7000 as expressVPN and Orbi as home router
billysboutin
I plan to add expressVPN to my network. I currently use the Orbi RBR20 router and 2 satellies for my home network. I have a R7000 WiFi router that was replaced by the Orbi router and satellites. I have turned off the wifi on the R7000 and set it to AP mode to have access to its ReadySHARE ability. I learned that the R7000 supports expressVPN but Orbi does not. Can I place the R7000 between my fios network and the orbi router and still maintain the configuration such as IP address reservation I set up on the Orbi router?
Model: R7000|AC1900 Smart WIFI Router, RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 3
Accepted Solutions
billysboutin
Re: Using r7000 as expressVPN and Orbi as home router
Message 3 of 3
All Replies
Guru
Please post about this here for your model router:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Good Luck.
Message 2 of 3
billysboutin
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1199 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
