Reply
Highlighted
VLAN Configuration
How do I disable VLAN function. I lost connectivity from my wireless router and unable to reconnect to it
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
Highlighted
Prodigy
Re: VLAN Configuration
if you have no access to the GUI reset the device to factory default.
FYI
VLAN feature is currently designed to separate WAN services provided by your service provider (ISP). For example, your ISP may require this feature in order to separate Internet, IPTV, and/or telephony services. It is not meant to be used to configure the LAN side.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1925 views
  • 0 kudos
  • 2 in conversation
Announcements
