Reply
VPN setup with NORDVPN
Hunter90
Follower
Having problems after downloading the OpenVpn software netgear tells you to download. I am not sure if im downloading the correct config files. The instructions are very vague for someone like me who is still learning about this. I just need some pointers or maybe a better explaination to set this up.
I purchase NordVPN and it works great on the laptop i initially installed it on. Im not very savy in this field and would just like to know what i am doing wrong during setup. I get an error that openvpn could not connect.
Also after turning off my VPN i can no longer access netgear router webpage without uninstalling NordVPN completely off my computer. Any reason for this?
Thank you for any insight you guys can give me.
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 2
Accepted Solutions
Guru
Re: VPN setup with NORDVPN
https://kb.netgear.com/966/Troubleshooting-VPN-passthrough-for-home-routers
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 2
All Replies
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 20025 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
