Reply
Highlighted
Tutor
VPN setup
I'm sorry if this has already been asked but I am having huge trouble with virgin media YouTube and Netflix buffering, can I set up a vpn on my Nighthawk router so that everything on my network goes through a VPN? A lot of my devices are not computers so clients can not be installed on them, if the router is set with the VPN would all devices connected to it be utalsiaing the VPN? Obviously there ip would be in my range but outside traffic will think it's coming from somewhere other than Virgin media servers.
Thanks for reading
Message 1 of 4
Accepted Solutions
Highlighted
Master
Re: VPN setup
Hi Smokie365,
That is correct. The router can only be set as the VPN server via the OpenVPN and passthrough if using other VPN service but will be able to do configuration as a client.
JamesGL
Community Team
Message 4 of 4
All Replies
Highlighted
Master
Re: VPN setup
Hi Smokie365,
The router can serve as the VPN server via the OpenVPN but it cannot be set as the VPN client. If you have other VPN server then the router can be a VPN passthrough.
JamesGL
Community Team
Message 2 of 4
Highlighted
Tutor
Re: VPN setup
Thanks James
So what I am looking for is not available unless I go with ddrt or something similar??
Message 3 of 4
Highlighted
Master
Re: VPN setup
Hi Smokie365,
JamesGL
Community Team
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3801 views
  • 1 kudo
  • 2 in conversation
Announcements
