Reply
View Ethernet Ports IP addresses of r7000
svodon
Follower
Where can I find the IP addresses of devices connected through the ethernet ports? When I look at the list of connected devices they all indicate that they are wireless Lee connected
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
antinode
Guru
Re: View Ethernet Ports IP addresses of r7000
> [...] r7000
   Firmware version?
   Where did you find what you did find?  BASIC > Attached Devices
should work.  ADVANCED > Administration > Attached Devices should be
equivalent.
   Are you seeing wired devices in the "Wireless Devices" category, or
do they not appear anywhere?  It sounds (to me) like a firmware bug.
You could try loading different versions.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 174 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
