Reply
Vizio E24 SmartTV wont connect to 6700v2
ksuwildkat
Follower
I have two Vizio E24i TVs (one is an A1 and one is a B1).  Neither can connect to my Nighthawk 6700v2.  Both can connect to other older routers.  I have done the following:
Factory reset on the TV
Confirmed that the TV can connect to other routers
Connected to the 6700 over a wirted connection
Confirmed that the system is not being blocked by access control
Verified the SSID and password are correct
Confirmed tha thr encruption type is correct
This seems to be specific to older Vizio TVs as my newer E48-C2 connects correctly.
Thanking you in advance
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Vizio E24 SmartTV wont connect to 6700v2
Do the TVs connect to the network but do not get an Internet connection? Or does it not even connect at all to the SSID?
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 191 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
