Reply
WAN connection dropped - had to reboot - logs useless
N6AC
Apprentice
The router dropped the WAN connection - We had to reboot - the router logs are useless since they show only since-boot events.
When I first got this router eight weeks ago, I was happy with higher LAN WiFi signal levels and hopeful about multiple fundtions for USB3 hard drive - now I can't even trust it to stay connected ???
Message 1 of 5
jmizoguchi
Virtuoso
Re: WAN connection dropped - had to reboot - logs useless
Are you testing both wired and wireless for WAN drop?
If you login the router and trying to ping out does still work or not?
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 5
N6AC
Apprentice
both wired and wireless LAN were unable to get internet.
tried reboot of cable modem, no luck.
reboot of R7000 brought web connectivity back.
Message 3 of 5
Retired_Member
Not applicable
If you updated FW did you default all settings then re-enter manually?
Message 4 of 5
N6AC
Apprentice
have not updated fw in about 6 weeks
we are on R7000_V1.0.3.24_1.1.20
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 2347 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
