× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
WAN not found using LTE
MiFireGuy
Follower
Hello!
I am trying to link my MR1100 to my R7450 via the WAN port on the router. I have went into the MR1100 and turned off wifi, enabled ip pass through, turned off the dhcp, and disabled the 2 minute ethernet connection. No luck
I also went in and changed the DNS & IP configurations to ISP Automatically Sets instead of using Static.... still no luck.
It shows that they are communicating because when I go back into the 7450 you can see where the 1100 set the ip and DNS. I also know the 1100 is working because if plug ethernet cable directly into my laptop it connects just fine.
I feel like I'm missing something simple here... Any help is appreciated
Model: MR1100|Nighthawk M1 Mobile Router, R7450|Nighthawk AC2600 Smart WiFi Router
Message 1 of 4
Blanca_O
NETGEAR Moderator
Re: WAN not found using LTE
Hi MiFireGuy,
Welcome to NETGEAR Community!
What is the IP address when connected to MR1100?
May we please know the device SKU (MR1100-100xxx) and firmware version of MR1100?
Blanca
Community Team
Message 2 of 4
TimRy
Try your config, but do not enable IP passthrough.
Message 3 of 4
TimRy
Depending on your ISP - enable 'DHCP' for the internet connection type on the router that is connected to the M1.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1039 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
