- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WD My Book HDD not being detected in For R7300
- Mark as New
- Bookmark
- Subscribe
- Permalink
I connected my External WD Passport 4TB HDD to usb 3.0. It is never getting discovered in network. What am i doing wrong?
WD passport model ---wdbyft0040bwt-0a
Netgear Version - V1.0.0.54_1.0.17
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you everyone. I was able to ersolve issue. I formatted to NTFS and it worked.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WD My Book HDD not being detected in For R7300
I tried with compatible HDD too. Dosent work. Only Pendrives works.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Western Digital My Passport USB3.0 2TB Model: WDBY8L0020BBK-PESN. This was the second device i tried
- Mark as New
- Bookmark
- Subscribe
- Permalink
What happens if you try the USB 2 port?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nothing . Not detected
- Mark as New
- Bookmark
- Subscribe
- Permalink
4TB is getting into "too big" for this technology. Is your device on this list?
ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
You don't say which format you have.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried with 2TB which is on the list and fully compatible. That also didnt worked.
Format of all the HDD's ExFat.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That may well be the source of the problem. None of the manuals in my library suggests that ReadyShare supports ExFAT.
It mostly offers "the following file system types for full read/write access":
- FAT16
- FAT32
- NTFS
- NTFS with compression format enabled
- Ext2
- Ext3
- Ext4
- HFS
- HFS
Why did you go for exFAT? Won't NTFS work?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I went for exfat because i wanted HDD to be read both in MAC and Windows. I can try reformatting one of the HDD to NTFS and try
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you Micheal. Yes after through several articles and purchasing few softwares , I was fed up and finally formatted to exfat. Any way altogether that a different issue. I wil ltry formatting HDD to NTFS and let you know the results. Appreciate your help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has Apple entered the 21st century and started to support NTFS?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well done.
You might like to mark your message as "solved". In that way the forum's search engine will flag it up and later visitors with the same issue should be able to find it more quickly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
