Orbi WiFi 7 RBE973
Reply
WIFI
Roveta
Follower
WIFI
I have a Netgear AC1750 R6400v2 and it is common to appear "without internet access" I found that changing the wifi password it works again. I suspect it is something associated with DHCP. Has anyone seen something like that?
Note: the problem is only with WIFI access, the wired network works normally.
Note1: I have about 30 devices connected to the wifi (SONOFF) and changing the password on all of them every "15" days is complicated.
I appreciate the help.
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 2
Guru
Re: WIFI
what firmware is on it?
What modem are you connected to?
Does a reboot fix it?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 296 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
