chrisarme
Dec 23, 2020Tutor
WN3500RP WiFi extender update
I have received an email stating that my old extender needs a security update.
I cannot find out how to do this.
Would you advise buying a newer model if they are an improvement on my existing one?
With thanks from an 80 year old non- tech savvy geriatric
epags1 try tftp/nmrpflash to fix it.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
if that doesn't work, start your own thread and we can work on fixing it.
the wn3500rp is a bit older of an extender but if its still working and hitting the speeds you need, you don't NEED to replace it.
Most firmware updates don't add features at this point but fix security issues.
The manual goes over how to manually update firmware.
You can find the firmware and manual here:
https://www.netgear.com/support/product/WN3500RP.aspx
Check which version you're on before updating to ensure you actually behind. Sometimes those emails are auto sent out and people aren't actually behind.
- epags1Aspirant
Just tried to update to the latest firmware version and bricked the extender. Don't do it if it is working.
Yes, I tried to reset to factory but that doesn't work either.
Sigh
