Arkarayn's avatar
Arkarayn
Follower
Aug 02, 2021
WNCE3001 problems with firmware upgrade
I have spikes of connection lag/shutdown for few seconds every 2 or 3 minutes, for the rest of the time the connection  is perfect, I wanted to try upgrading the firmware but in a page it says to download a zip and then open the .exe file(there isn't any .exe file in that zip) and in another one it says to register on routerlogin.net (that's what I did) and then go to the settings but I can't seem to find these settings anywhere in the entire page.
Thanks
1 Reply
  • > [...] in a page it says [...]
       _Which_ "a page"?  Thanks for the helpful link.
    > [...] in another one it says [...]
       _Which_ "another one"?  Thanks for the helpful link.
       Does anything in either of those (secret) "pages" suggest that it
    applies to your device?
       Did you consider trying this radical concept (which works for some
    people):
          https://en.wikipedia.org/wiki/RTFM
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual (at least).  Read.  Look for
    "Upgrade the Firmware".
       If you've already downloaded the kit, and extracted the files from
    it, then you might try reading the Release Notes file which is provided
    in the kit.
