Orbi WiFi 7 RBE973
Reply
WNR3500Lv2 with Nighthawk X10 R9000
jharrell
I know that the WNR3500Lv2 has an Access Point mode, can this be used with the Nighthawk X10 ?
Model: WNR3500Lv2|N300 Wireless Gigabit Router|EOL
Message 1 of 4
Accepted Solutions
Re: WNR3500Lv2 with Nighthawk X10 R9000
@jharrell wrote:
I want to move the WNR3500Lv2 to my garage to have better WiFi converage. I have a Nighthawk X10 R9000.
Should work well. If you can run a network cable to the garage. That's how AP mode works.
If it is too far to run a network cable, and the garage is on the same mains circuit as the router without too many fuse boxes, you could consider Powerline Ethernet as a way of wiring the WNR3500Lv2 back to the router.
Message 4 of 4
All Replies
What do you have in mind?
Which Nighthawk X10?
Put WNR3500Lv2 into AP mode. Plug into other router.
Away you go.
Message 2 of 4
jharrell
Message 3 of 4
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 758 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
