- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WPA password and Security key for use with HP Printer Where do I get them. Did not come with my Cabl
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: WPA password and Security key for use with HP Printer Where do I get them. Did not come with my
What modem/router/device do you have?
did you setup/change your ssid/password?
If you go to netgear.com/support/ type in your actual model number. It takes you to guides, firmware, etc for help
1.4gig download/50mbps upload
We’re members of the public helping out on our own time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Start by explaining what you are trying to do. (And don't try to squeeze everything into your subject line, it is painful to read, especially when you run out of room.) It may be that you don't need the information you listed.
It sounds like you are trying to user wifi to connect an unnamed HP printer to an unnamed Netgear router.
The usual way to fix wifi printers is to find the printer maker's utility, the software that runs on your operating system. Then use that to connect the printer to the wifi.
Installing HP wireless printer software | Wireless Printing Center | HP® United Kingdom
The router just broadcasts wifi. It is then down to the printer to play ball.
Where possible, using the WPS feature can simplify things. (That's often just a case of pushing buttons.)
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40VUser | Count |
15 | |
10 | |
9 | |
5 | |
4 |
