- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WPS PIN doesn't stay deactivated
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
For security reasons I try to deactivate the WPS PIN in admin webpage (Advanced->Advanced Setup->Wireless Settings->WPS Settings->Router PIN).
But if I uncheck it and apply the changes, the checkbox is checked again after admin webpage reloaded, so no way to deactivated this PIN.
I also already tried to again login on admin webpage or restart the whole router after applying the changes, but the checkbox is still checked again.
My router runs on firmware V1.0.9.64_10.2.64
Does anyone know a solution for that?
Thanks in advance!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
this is a known defect of the R7000 firmware. Others have reported the same problem. No fix yet until NG fixes it (if at all)
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WPS PIN doesn't stay deactivated
Oh, that's bad news as the WPS PIN was identified as security risk and you have now no possibility to protect against it (and you not even have the possibility to turn of WPS at all)...
But anyway thanks for confirmation of this issue!
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's hard to belive this cannot be turned off. After all I've read about what a security risk this option is, Netgear doesn't have a fix?
Absurd!
