Reply
Highlighted
Follower
WPS button, where is it pn nighthawk x4s ac2600
Cant get to work with LG TV
Model: R7450|Nighthawk AC2600 Smart WiFi Router
Message 1 of 3
Highlighted
NETGEAR Moderator
Re: WPS button, where is it pn nighthawk x4s ac2600
Have you tried to connect the tv with entering in the SSID and the password rather than using WPS?
DarrenM
Message 2 of 3
Highlighted
Guru
> WPS button, where is it [...]
      https://en.wikipedia.org/wiki/RTFM
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Read.  Look for "WPS"?
> Can[']t get to work with LG TV
   "Can't" is not a useful problem description.  It does not say what
you did.  It does not say what happened when you did it.  As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
   LG makes more than one model of television receiver.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 719 views
  • 0 kudos
  • 3 in conversation
Announcements
