Orbi WiFi 7 RBE973
Reply
Wall mount Nighthawk CM 2000
rpee47
Follower
Has anyone tried to wall mount a Nighthawk 2000 CM cable modem?  There's no Netgear solution, and the flared base makes the product to wide to fit traditional cable modem wall attachments.
Message 1 of 2
Guru
Re: Wall mount Nighthawk CM 2000
I haven't seen any wall mount options and I doubt you will. The CM2000 needs good airflow (heat is the death of electronics) and wall mounting it is going to block a whole side of airflow.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 839 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
