Reply
Want to use my R7000 as a extender for my iPhones wifi
Johan_Ek
Follower
Waiting for fiber later this month and have alot of unused GB on my cellular. But i dont know how to configuar the router?
Message 1 of 2
TheEther
Guru
Re: Want to use my R7000 as a extender for my iPhones wifi
The R7000 is not well suited to extending Wi-Fi using stock firmware, but see bottom.  A range extender would be a better choice.
The R7000 has an older wireless repeating feature called WDS.  It only supports WEP security or no security at all, so it probably won't work with the iPhone.
You could use the R7000 as a wireless bridge.  In this mode, the R7000 connects to the iPhone's Wi-Fi but only clients wired into the R7000's Ethernet port are supported.
As I hinted above, there are 3rd party firmwares that have better support for wireless repeating.  There is Asuswrt-Merlin, DD-WRT and Tomato.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1501 views
  • 1 kudo
  • 2 in conversation
Announcements
