Reply
We have a Nighthawk R7000. Slow speed. Only 72, when line allows 300
DoctorWhoSC
Follower
We have a Nighthawk R7000 and our internet provider recently allowed all customers to connect at 300mps. We seem to be only getting 72mps. Are there configuration changes I can make to allow the higher speed?
Message 1 of 3
William10a
Master
Re: We have a Nighthawk R7000. Slow speed. Only 72, when line allows 300
You may need to reboot your network for it to see the new speed.
Message 2 of 3
myersw
Master
Did you have QoS turned on? If so turn it off and try again. Also, as suggested by other forum member, reboot the router. I would probably use the unplug wait for about 30 seconds then plug back in process. For some reason I have had a power cycle rather then turning off and on fix things.
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 234 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
