Discussion stats
  • 1 reply
  • 95 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
Follower
Weird internet problem with Nighthawk AC1750
Okay so, I just got the Nighthawk AC1750. My modem is the motorola SB6190. I'm on the 400 MB/s tier with spectrum. When wired directly to the modem my speedtest is over 400 mb/s, when wired to the nighthawk, between 17-30. If I use wifi and connect to the router, I also get the same slow speeds. However if I connect with my phone I can speedtest over 400 mb/s on wifi... Connected to the same network as my PC.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 2
Highlighted
Guru
Re: Weird internet problem with Nighthawk AC1750
What firmware are you on?
What version of the R6700 are you on?
Have you tried swapping cables?
Or if you just bought it and upgraded your firmware, a factory reset can help if the firmware has changed enough.
CAX80->GS716v2->RBR50->RBS50-RBS40V-RBS50Y
Message 2 of 2
