Reply
Weird occurrence with portforwarding
iiWorld
Been trying to portfoward 27000-27050 for steam connections. The problem that I am actually having is that connections to game servers on steam are around 500+ ping. I plug it into modem, connections around 60 ping. Figured out I had connected the port to the wrong IP the whole time, switched it to the correct IP and it started working for maybe a whole 2 minutes then reverted back to the same problem. I don't understand what happened.
Message 1 of 5
jmizoguchi
Virtuoso
Re: Weird occurrence with portforwarding
Have you test with DMZ for server ?
Some of the game server gets a hits from many of other server and may flooding the router.
You can also try disable SPI or DoS ( you will find only either one) and that may help from firewall on the router to choke up
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 5
iiWorld
Sadly steam doesn't allow play through with DMZ servers. I have also tried disabling the DoS firewall but still, no luck.
Message 3 of 5
jmizoguchi
Virtuoso
There is very few setting that can results the issues but that is all gone.
I would contact support for assistance.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 5
iiWorld
Found the fix with the help of Netgear support.
The issue was that my computer IP was continuously changing.
Add a reserved IP for your computer and change the portforwarding to that reserved IP.
Everything appears to work now. Thank you for the help!
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1783 views
  • 0 kudos
  • 2 in conversation
Announcements
