Orbi WiFi 7 RBE973
Reply
What are the steps/instructions to USB Tethering Cellphone with PdaDet to Nighthawk?
Dunes
I have tried searching the Community and Google.  I would like to USB tether my phone with PdaNet to router.
What are the settings/instructions to set up router?  I can tether phone to PC via USB and it works great!  I do have Windows 10 with mobile hotspot but having issues on getting that to work when I am connected via USB tethering to PC.
Any help would be gladly appreciated as I know one and/or both above scenarios will work but not quite sure on the settings.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 6
Accepted Solutions
Dunes
Re: What are the steps/instructions to USB Tethering Cellphone with PdaDet to Nighthawk?
Thank you very much for the replies! I really appreciate it as this saved me hours of chasing something that is not there! 🙂
Great Community Support!
Message 6 of 6
All Replies
Guru
I know of no way to use your cell phone as the internet connection for a Nighthawk router.
Message 2 of 6
Dunes
Thank you for your quick response!  I read forums on where Asus routers could be used in the same scenerio as above.
Message 3 of 6
JamesGL
Master
Hi Dunes,
I will confirm what StephenB answered. NETGEAR routers will not work with USB Tethering connections. The USB ports are used for external drives and usb printers.
Message 4 of 6
JamesGL
Master
Hi Dunes,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
Message 5 of 6
Dunes
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 34467 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
