Reply
What causes R7000 to disconnect?
StanH
Tutor
My R7000 disconnects my wired Dell T1700 daily, sometimes hourly. What might be causing this?
Message 1 of 6
StanH
Tutor
Re: What causes R7000 to disconnect?
More Information: Genie v2.4.60 Firmware V1.0.9.64
Message 2 of 6
yddtime
Luminary
Did you search this forum for "R7000 1.0.9.64"? You are not the first one to have this issue.
R7000 is in the recycle bin
Message 3 of 6
IrvSp
Master
That is your answer... go back to V1.0.9.42, should solve the problem.
Message 4 of 6
StanH
Tutor
Where can I find downloads for previous version V1.0.9.42?
Message 5 of 6
antinode
Guru
> Where can I find downloads for previous version [...]
   Visit http://netgear.com/support , put in your model number, and look
for Downloads.  (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".)  Find the kit(s).
Download the kit(s) you want.  Read the "Release Notes" file for
instructions.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 655 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
