Reply
What is dual band with 2.4/5 and n/ac
I own a netgear WNDR4300 simultaneous dual band router. Dual band is for me 802.11n on both 5GHz and 2.4GHz simultaneously. How is that on the AC1900? What I like to accomplish is simultaneous 802.11n 2.4GHz, 802.11n 5GHz and 802.11ac 5GHz. I read all specs but I cannot figure out if the AC1900 can do that.
Maybe someone can connect the dots for me.
Message 1 of 7
Babylon5
NETGEAR Employee Retired
Re: What is dual band with 2.4/5 and n/ac
I use an R7000 with a variety of WiFi clients of differing capabilities e.g. ‘b/g’, ‘b/g/n’, ‘b/g/n/AC’ and I don’t see any significant compromises with any device even when operating ‘simultaneously’.
____________________________
Working on behalf of Netgear
My name is Andy
Message 2 of 7
HiSpeed
Guide
Same thing for me... R7000 is a good product... I'm only waiting firmware improvements...
● Netgear R7000 (Root Router)
● TP-Link Archer C7 v2 (WDS Bridge)
Message 3 of 7
Thanks, a R7000 it will be then.
Message 4 of 7
Ok, since you are waiting improvements, what issues do you encounter?
Message 5 of 7
HiSpeed
Guide
They are discussed somewhere in this forum...
Nevertheless, the major point where TP-Link is much better than Netgear is the WDS bridging. It works easily with WPA2-AES encryption when Netgear requires WEP + crossed MAC addresses...
Message 6 of 7
Ok, got it. That is why I did not use WDS bridging since it will make the whole network vulnerable using WEP.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 5956 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
