× Some paid Circle Parental controls customers may be showing free options only. Router firmware correcting this issue will be available ASAP. Visit Status.NETGEAR.com for updates.
Discussion stats
  • 2 replies
  • 154 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
What is the difference
I need to replace my Nighthawk R7000. I'd like to know the difference, if any, between the following routers. New from Best Buy $200.00 and used from Amazon $125.00. Can you help?  Bill NETGEAR - Nighthawk X6 AC3200 Tri-Band Wi-Fi 5 Router - Black
Model:R8000-100NAS
SKU:7201035
Best Buy $199.00
NETGEAR Nighthawk X6 Smart WiFi Router (R8000) - AC3200 Tri-band Wireless Speed (up to 3200 Mbps) | Up to 3500 sq ft Coverage & 50 Devices | 4 x 1G Ethernet and 2 USB ports | Armor Security
Used from Amazon $124.00 30 Day Return
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 3
Highlighted
Guru
Re: What is the difference
Difference?
one's used and one isn't.
They're both an R8000.
CM1100->RAX200->GS716v2->RBR50->RBS50-RBS40V-RBS50Y
Message 2 of 3
Highlighted
Thanks, It seemed obvious to me but I wanted to be  certain before I purchased the used one. Thanks again
Message 3 of 3
