- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
What is the max speed I should expect from the Nighthawk R7000?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Hi, I just got hooked up to At&t 1 gig Fiber and wondered what speed to expect. I have some slowdown on my LAN that limits it to 100 Mbps at this time. Have to try a laptop hooked onto the At&t modem. Not sure what could be slowing it down. Perhaps wired house wall plugs. When I test from the Nighthawk app I see 400 Mbps up and down from Speed test. Is that to the Internet or just my At&t modem? Should it be higher on gig connection from Nighthawk box to Internet?
Any advice appreciated...
Steve
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: What is the max speed I should expect from the Nighthawk R7000?
Wifi speeds or wired speeds?
What is the AT&T modem?
Have you disabled QoS?
What are these "wired house wall plugs"?
Some older LAN devices are limited to 100 Mbps. It is down to the hardware.
There is support for the R7000P, including a manual, somewhere at the end of this link:
There is support material, including a manual, for the R7000 somewhere at the end of this link:
>>>> R7000 | Product | Support | NETGEAR <<<<
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
wifi is 200 Mbps, Wired is 100 Mbps. Plugging LAN cable into Nighthawk with a laptop directly I get 400 Mbps. So I
need to test my houses internal cables and outlets.
Have to look it up, a UVerse box.
Have you disabled QoS? Have not tested that.
No
Gigabite switch in the wall unit.
Upgraded all switches to gigabit.
Thanks
